Lakers23206's avatar
Lakers23206
Initiate
Apr 15, 2020
No internet connection through wired connection from ac750 WiFi extender
I’m having issues connecting through wired connection from the WiFi extender, it was working fine and connected with not issues through a wired connection from the extender to the pc but since my rout...
  • plemans's avatar
    Apr 15, 2020
    Have you reset the router? From the sounds of it, the router turning on/off was the initial cause. Maybe it corrupted something in the router
