Lakers23206
Apr 15, 2020Initiate
No internet connection through wired connection from ac750 WiFi extender
I’m having issues connecting through wired connection from the WiFi extender, it was working fine and connected with not issues through a wired connection from the extender to the pc but since my rout...
- Apr 15, 2020
Have you reset the router? From the sounds of it, the router turning on/off was the initial cause. Maybe it corrupted something in the router
Apr 15, 2020Guru - Experienced User
Lakers23206
FIXED: all working again, I did reset the router last night after it was first turned off and back on but I have tried again and it seems to be fine, though a simple one I’m glad I posted!
Thank you for your help.
