djmc
Sep 15, 2011Aspirant
No internet connection to WN3000P
Bought a WN3000RP this morning to extend the range of my reliable FWG114P. All seemed to set-up correctly but when finished, the new ******_EXT connection fails to get internet connectivity. The FW...
djmc
Sep 17, 2011Aspirant
Spock wrote: First, Check in your router if you are able to receive Internet radio type 802.11n . After connecting the product to my router I still could not connect to Internet. I have a WRT610n Linksys router.On the router: I had to change the Network mode to "Mixed" to make it work. The reason is that the WN3000RP works on an Internet radio type 802.11n and if you have your router programmed for 802.11g like me, it would never work.
I was using a Linksys WRT320N but it stopped working about a year ago.
Reinstalled the Netgear FWG114P because it still works well but is only G [& B].
My thought was that newer N devices would still support legacy G products; guess I was wrong.
To anyone:
Any suggestions as to what router I should be using?
