djmc
Sep 15, 2011Aspirant
No internet connection to WN3000P
Bought a WN3000RP this morning to extend the range of my reliable FWG114P. All seemed to set-up correctly but when finished, the new ******_EXT connection fails to get internet connectivity. The FW...
TomOlsson
Oct 17, 2011Aspirant
I am having a similar problem. The WN3000RP range extender installed fine and was working fine. Then after a week or so decided I needed to reconfigure it, that is, when I tried to go to the web it brought up the mywifiext.net page and asked me to step through a number of config steps. Still did not connect to the Internet. The router was connected fine and I could get to the internet by connecting directly to it but not via the extender.
After turning the extender on and off, re-setting and so on, eventually it connected to the Internet again. A day or two later, no connection. Re-set, and all is fine... then it is off again.
The signal is always 100% and when it is working it works very well. But at this point it has become unused as the family is too frustrated with it and have gone back to being connected to the router wifi which has a low signal strength but at least it is there.
My wifi router is a Netgear DG834G.
Any help appreciated.
Tom
Tom
