rollerrrr
Jul 22, 2020Follower
No internet connection via wire
I have an EX8000 wifi extender connected to my C7000 routers. In the past 2 months, I found that every two or three days devices connected to the extender via an Ethernet cable will have no internet ...
- Jul 23, 2020
Which firmware is on the EX8000?
Have you tried reinstalling the current firmware on the EX8000, resetting it, and then reinstalling it?
Sometimes an old setting could cause issues or corrupt firmware. By reinstalling and resetting, you'd overwrite any corrupt firmware and remove any bad settings.
Jul 23, 2020Guru - Experienced User
