donblick
Jan 01, 2013Aspirant
No internet Connection
Hi, I try to Setup rh wn1000rp with a speedport v701 dsl Router. Using the wizard works fine and a _ext Network is set up which i can connect to. Unfortunately i cant connect to the internet,Mos...
mistert123
Feb 01, 2013Aspirant
go in to Wireless Settings under Security Options you should see WEP select that and in
Key 1:
put your wifi password.that should fix it
Key 1:
