donblick
Jan 01, 2013Aspirant
No internet Connection
Hi, I try to Setup rh wn1000rp with a speedport v701 dsl Router. Using the wizard works fine and a _ext Network is set up which i can connect to. Unfortunately i cant connect to the internet,Mos...
romeylo
Feb 10, 2013Aspirant
Hello,
i`ve the same problem with the repeater. The connection in the homenetwork is simple but it won`t conect to the internet. I`ve test a lot of scope but the internet don`t work.
What can i do? Anyone an idea?
Best regards
Roland
Best regards
Roland
