StefSavanah
Mar 20, 2019Aspirant
No internet on 2gEXT yet there is on 5gEXT
My extender is about a year old and has mostly worked OK. I usually connect to internet on the 2gEXT signal but although I can connect to teh network I get a message that there is no internet connect...
Mar 20, 2019Guru - Experienced User
What Firmware version is loaded on the EX?
What is the Mfr and model# of the main host router the NG extender is connected too?
What is the distance between the main host router and the EX unit?
What channels are you using on the main host router?
Are connections on 2.4Ghz on the main host router good?
- StefSavanahMar 21, 2019Aspirant
>>> latest firmware is installed
What is the Mfr and model# of the main host router the NG extender is connected too?>>> Sky Hub, model ER115
>>> about 10 metres. Hub is downstairs, extender one floor up
>>> on the page for 2.4GHz it is set to 'auto' in the drop down list. The drop down is a list of integers from 1 to 13. On the 5GHz page it is set to '80MHz ch.36'. The drop down has two other options: '40MHz ch.36' and '40MHz ch.4'
>>> Yes, I can reach the internet when connected to directly to the main router.
>>> also these settings exist:
Wireless Access Point
✔ Enable Wireless Access Point
✔ Enable WPS
✔ Allow Broadcast of Name (SSID)
Synchronise 2.4GHz and 5GHz Settings
>>> i.e. 2.4/5 are not 'synchronised' - if that makes a difference?
Thanks for your help
OK, so I just tried ticking the 2.4/5 synchronise option and - lo and behold - it works. Thanks...
- FURRYe38Mar 21, 2019Guru - Experienced User
Are you using the EX as an extender or in AP mode wired to the main host router. If Extender, then I would try disabling Wireless Access Point. Ensure the EX is setup for Extender mode, this would and should sync channels with the main host router.
