griz8214
Sep 17, 2011Aspirant
no "manage wireless network" in Vista SP2 control panel
I do not see the Manage Wireless Network option in the Vista SP2 control panel so can not access the Netgear router. The router is working as another computer in the house is accessing it, and the pr...
jmizoguchi
Sep 17, 2011Virtuoso
if you are NOT able to see SSID of the router you are using then possible you have an issue with wireless on router? But assume other wifi device is connected?
