griz8214
Sep 17, 2011Aspirant
no "manage wireless network" in Vista SP2 control panel
I do not see the Manage Wireless Network option in the Vista SP2 control panel so can not access the Netgear router. The router is working as another computer in the house is accessing it, and the pr...
jmizoguchi
Sep 17, 2011Virtuoso
sounds like either adapter you are using is not seated correctly or if this is USB adapter, use different USB ports and/or not sure share USB port with other USB products
