griz8214
Sep 17, 2011Aspirant
no "manage wireless network" in Vista SP2 control panel
I do not see the Manage Wireless Network option in the Vista SP2 control panel so can not access the Netgear router. The router is working as another computer in the house is accessing it, and the pr...
anandfbd
Sep 22, 2011Aspirant
Well!! If you do not see manage wireless connection on the Network and Sharing center screen on your Vista computer then that clearly indicates that the wireless adapter on the computer is either not installed or it is facing certain software issues.
To isolate the issue, check the device manager on the computer and locate the wireless adapter in it. I am dead sure that the wireless adapter software/driver is not installed properly on the computer and requires reinstallation.
Thanks
Anand Gupta
Thanks
Anand Gupta
