OSW75
Mar 06, 2021Aspirant
No roaming between two EX8000
Config description: I have a network consisting of an Orange LiveBox Router and a wifi network supported by 2x EX8000 Mesh Extenders and a single SSID: one is the access point and the other one the ...
OSW75
Sorry for the mistake, but the EX8000 extender using the channel 100 + 104(p) + 108 + 112.
Cheers,
Osw
michaelkenward
Mar 06, 2021Guru - Experienced User
The EX8000 isn't a Mesh extender. (Netgear has implemented this on some extenders.) So handovers won't be as smooth.
Mesh fills the place with a single networkall on the same SSID.
When these handover issue happen it can be down to the wifi clients as much as the router. The client has to negotiate a new connection on its own, with a different SSID and password, with not much help from the wifi sources.
Using the same SSID for two different sources could actually cause more problems than benefits. Have you tried different SSIDs? (The password can be the same, mine is.)
This might be useful reading:
WiFi Range Extender Best Setup Guide | Router Guide
Have you tried tweaking the wifi clients rather than the extender?
- OSW75Mar 06, 2021Aspirant
Thanks Michael,
I bought specially this extender because the "Seamless roaming". But I understand that it is not seamless at all ... and what I'll do, it will not be a clean handover. Correct ?
What do you mean by tweaking the IP on the client ?
Cheers,
Oswald
- michaelkenwardMar 06, 2021Guru - Experienced User
That was a reference to the link between the router and an extender. Not two extenders. I just check the datasheet. That is, of course, a marketing tool.
The manual is silent on the subject of "seamless connectivity".
Your first message referred to "2x EX8000 Mesh Extenders". Where did you the MESH bit come from? Did Netgear add that in later firmware?
That's not what I said. Just look at the settings on the wifi clients and see if there is anything you can change to make a difference.
Thanks Michael,
I bought two extenders EX8000 because of the smart roaming function.
Smart Roaming
Smart Roaming intelligently connects your mobile devices to the optimal WiFi for 4K streaming, surfing and more. Now you can enjoy uninterrupted streaming on YouTube or Netflix, even as you move around the house.
https://www.netgear.com/home/wifi/range-extenders/ex8000/
I never been desapointed of Netgear products ... I assume it's a problem of configuration.
Can you please help ?
In the time, I'll investigate the IP parameter on the devices.
Best regards,
Oswald
