steveteahen
Oct 11, 2020Aspirant
no wifi comes up on my wifi settings AC750 model ex6100v2
Netgear does not show up on my wifi setup
Oct 12, 2020Guru - Experienced User
Did you setup the extender already using wps or the installation assistant?
If you set it up already, the EX6100v2 is default a mesh extender. Meaning it uses the same ssid (name) as the router. so it won't show up different unless you manually set it up different.
steveteahen
Oct 12, 2020Aspirant
I used the WPS and it shows up on the unit!
