steveteahen
Oct 11, 2020Aspirant
no wifi comes up on my wifi settings AC750 model ex6100v2
Netgear does not show up on my wifi setup
steveteahen
Oct 12, 2020Aspirant
the LED is not on showing the client link!! only light that is not on.
Oct 12, 2020Guru - Experienced User
If you set it up using wps, its running in mesh mode. meaning it has the same ssid as the router.
You won't see the "client link" led light up until a device connects to it. In mesh mode, its the device itself (cell phone, tablet, etc) that roams between the router and the extender.
- steveteahenOct 12, 2020AspirantSo how do I tell if it is doing what it should be doing
- plemansOct 12, 2020Guru - Experienced User
does it extender your coverage?
If you log into the client, whats it show for a status page?
Is anything connecting to it? give it a little time as devices need to migrate to it based off their own protocols.
- steveteahenOct 13, 2020Aspirant
from the beginning of the setup, there has never been a NETGEAR wifi chouse on my settings or on the app.
