paperlai's avatar
paperlai
Noobie question
Hoping you all will be able to help
I've got a Netgear DGN2200 connected to a netgear wnr612 via ethernet (using netgear powerlines)
I have a QNAP connected (via ethernet) to the DGN 2200
and I have my laptop and xbox360 on the WNR612.
Issue I have is that the laptop and xbox360 can't recognise the QNAP.
How do I need to setup the routers so that it can be one network, I've been trying to set it up as a wireless repeater not sure if this is the right option.
look forward to any advice you can give
