Scott123
Dec 31, 2012Aspirant
NOOK Tablet MAC Filtering Problem
When I first purchased my NOOK Tablet, I linked to the internet and the NOOK bookstore and purchased a book. That was about 2 or 3 weeks ago. It worked fine. This is at my home address and I have the ...
jmizoguchi
Dec 31, 2012Virtuoso
I would say you need to change wireless mode from "auto 108Mbps" to B &G mode or G only under wireless settings
yes, bottom of the router's IP should give you a prompt with at user/pass
user admin
pass password ( if you have not changed in the past)
You should access the route with computer using ethernet cable . Also wireless encryption type can cause issues you need to play with it.
user admin
