Vijayrchandran
Nov 29, 2022Aspirant
Not able to access configure EX6110
Have a couple of problems with my EX6110 WiFi Range Extender. 1. I am getting a security warning when I try to set up the extender, 2. If I do ignore the warning & try to set up the extender, it...
- Feb 25, 2023
If anyone else facing this issue try this.
Instead of entering the site address enter the IP address (192.168.1.250).
That worked for me. The only down side is that once you configured the extender you cant use this trick to enter the extender.
Vijay.
Vijayrchandran
Feb 16, 2023Aspirant
Yeah. Still getting the same message whenever I try to get into the extender.
Vijayrchandran
Feb 25, 2023Aspirant
Vijay.
