mahajanakhil
Feb 18, 2025Aspirant
Not able to access mywifiext on Mac because I enabled HTTPS
I enabled HTTPS for mywifiext.local and that seems to be the worst mistake of my life 🙂 This site can’t be reached The web page at https://mywifiext.local/ might be temporarily down or it...
Feb 19, 2025Guru - Experienced User
did you try using the ip address for it?
Or you could simply factory reset and reinstall.
- mahajanakhilFeb 19, 2025Aspirant
Yes I did. It did not work.
- plemansFeb 20, 2025Guru - Experienced User
You tried factory resetting?
