Krishna_A
Aug 13, 2023Aspirant
Not able to connect to my wifi ext after configuring range extender
I am not able to connect to my wifi ext after configuring my range extender. Any solution to this issue?
schumaku
Aug 13, 2023Guru - Experienced User
Difficult to answer.
Part of the extender config, is that your original WiFi network name and it's PSK (the wireless password) is configured on the extender, and two new network names are published for each band:
For example:
• Existing WiFi network name. MyNetworkName
• New extended network names. MyNetworkName_2GEXT and MyNetworkName_5GEXT
These are the two wireless network available, with the MyNetworkName_5GEXT covering a shorter range and higher speed than the MyNetworkName_2GEXT. The wireless password (PSK) is the same you have configured on the extender for the connection to the primary router WiFi.
