Krishna_A
Aug 13, 2023Aspirant
Not able to connect to my wifi ext after configuring range extender
I am not able to connect to my wifi ext after configuring my range extender. Any solution to this issue?
Krishna_A
schumaku Sorry, I did not understand your answer. Can you please clarify?
schumaku
Aug 13, 2023Guru - Experienced User
YHave run the Smart Setup process as shown NETGEAR AC1200 Dual Band WiF Range Extender Model EX6120 User Manual p.17 ?
The point is you wrote before having configured the extender:
Crystal ball is out of order here. Sorry, you have to explain what you have configured, if you see the new wireless names displayed on your mobile or Wi-Fi clients, ....this is why I have asked, even provided a generic named example config.
- Krishna_AAug 14, 2023Aspirant
schumaku This is how my wireless names appear after configuring the range extender. Krishna jio 5G_2GEXT Krishna jio 5G_5GEXT.
After connecting to any one of the above networks, I am not able to connect to my wifi ext.
- DexterJBAug 24, 2023NETGEAR Moderator
Hi Krishna_A , you can always reach our support team via the link below if you need any technical assistance with your NETGEAR device.
https://www.netgear.com/about/contact-us/
You can also call the number below.
1-888-NETGEAR (1-888-6384327)
Dexter
NETGEAR Team
