Edrx7
Jun 05, 2020Aspirant
Not sure it’s set up correctly
Currently I have the extender set up with “ext” as a suffix with the first part being my main router name. 1. To get a better signal do I have to connect directly to the routers SSID (ext) or does it...
Edrx7
Jun 15, 2020Aspirant
Anyone?
- Edrx7Jun 15, 2020AspirantAlso noticed that looking at the nighthawk app it only shows the ext name as having the 2.4 ghz!.... where has the 5ghz gone?
- DexterJBJul 09, 2020NETGEAR Moderator
Hi Edrx7, we'd love to answer your questions.Here are our thoughts.
- The EX7700 has a MESH/One WiFi Name feature. This means that you can set it up that it has the same WiFi name as your main WiFi router
- We recommend connecting your devices to whichever signal is the strongest at its location
- The user manual and installation guide linked below may help out
https://www.downloads.netgear.com/files/GDC/EX7700/EX7700_QSG_EN.pdf
https://www.downloads.netgear.com/files/GDC/EX7700/EX7700_UM_EN.pdf
Dexter
