Shasse
Jan 27, 2026Aspirant
Old extender to new ATT air hub?
I'm trying to connect my old N300 (model EX2700) wifi extender to my new internet service. I've done the factory reset, but can't get it to recognize my new Hub. Will I need to purchase a new exten...
- Jan 27, 2026
Is this the ATT Air Hub that you have?
https://www.att.com/device-support/article/wireless/000100597/ATT/ATTNCM1120D2D323/
Yes, moving the Hub to the center of the space is a better solution than using an old WiFi extender.
CrimpOn
Jan 27, 2026Guru - Experienced User
It appears that the AT&T Air Hub supports WPS. Have you tried using WPS to connect the EX2700?
