lspremulli
Apr 23, 2025Follower
old extender with 3 atenna
I have a very old netgear extender with 3 atenna. it does not have a model number on it.
I set it up with WPS and I see the network. EXT but I can't join, it just shows available, but I the iphone won't connect up, it just shows a circle near the name.
I am not very technical, any help or suggestions would be appreciated. I did reset the extender.
Thanks!
Linda
1 Reply
- there will be a lable on it with a model. that helps.
- Don't set it up with wps. Not all devices play well with wps (they should). Factory reset 1 more time, then set it up with the installation assistant. To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
