mpnret's avatar
mpnret
Tutor
Aug 12, 2019
One WiFi Name feature when EX8000 connected as access point
Can anyone confirm that the "One WiFi Name" feature actually works when when the EX8000 is connected as an access point? The option is missing from my settings. User manual indicates it should work. Tech support claims it should work but all they are really doing is reading the same user manual I am. My next step is to do a factory reset and reinstall as an extender with "One WiFi Name" feature enabled and then switch it over to access point and see if the feature holds. Any ideas?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Yea I would try what you just said and if not let me know I will report this as an issue.
    DarrenM
    • mpnret's avatar
      mpnret
      Tutor
      Yes, if you could report this as an issue I would appreciate it. Here is where I am so far: I have 2 EX8000s both on the latest firmware (V1.0.1.202). I have tried a number of factory resets and re-installs. Both have the same issue that being when installed as an access point (ethernet cable) there is no option for "One WiFI Name" or "Sync Configuration from Netgear Router" . These options are there when installed as an Extender (wireless). These options are under settings, wireless, general after logging on to the extender along with the "Enable Smart Connect" which is there in both cases. I realize I could manually name the SSID the same on both router and EX8000 but that will not give me a true mesh network. This same issue is reported a number of times in the community. Here is one link: https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/EX8000-or-similar-mesh-extender-w-wired-backhaul-and-single-SSID/td-p/1648920
      I called tech support case 41572794 and their only answer is factory reset and re-install. I ask for second level support and all I get is silence. I hope this issue can be resolved before my return window closes and I move on to Ubiquiti Mesh which is what the poster did in the link I provided above.
      Thanks, Mike
      • MobsterPhil's avatar
        MobsterPhil
        Hello Mike,
        Was this issue resolved in any way?
        I have exactly the same issue and exactly the same problem with the Netgear Support. Or should I say Netgear not support...
        They keep sending me user manuals with the same information. I also asked for a second line support to call me, but no answer.
        I think I also will have to switch to a competitor. Or should I say a company that delivers what they sell.
        Kind regards,
        Philip
