mtyck23
Nov 09, 2020Aspirant
only one band connects to the internet
wifi externder has always worked fine. we have just changed internet provider and installed new router. Did a factory reset on the AC1200 wifi extender. Both bands ext2 and ext 5 appear to be set-up ...
mtyck23
Nov 10, 2020Aspirant
Hi, Thanks for the suggestions. The router is Vodafone.
I have updated the firmware to the latest version 1.0.0.54 which made no difference, still only band 2 no band 5.
tried to link to router using wps and now cannot cannot connect at all with either band. the wifi on the laptop now keeps asking for the network key which i enter and then it just keeps asking for the key again.
feels like we are going backwards.
Nov 10, 2020Guru - Experienced User
1. Vodafone is a company. Its like a mechanic asking what car you're wanting repaired and saying "ford". It doesn't help. What model is it?
2. If wps caused issues, factory reset and reinstall again using the installation assistant. i don't usually recommend the wps method but its always worth a shot.
- mtyck23Nov 10, 2020AspirantHi
Voafone THG3000
Trying another factory reset.
Thanks
