rgerst's avatar
rgerst
onn brand streaming not working
I just installed the netgear wifi mesh extender. It works great for my phone and lap top, but my onn stick streaming does not.... it sees the network with great signal strength. but when you try to connect it says it cannot find it.... if I hook up my my rockspace wifi extender coming off of my netgear wifi it works fine... I got this so I would not have to use my rockspace one as I want to locate it somewhere else.
  • plemans's avatar
    What extender do you have?
    What router did you connect it to?
    What firmware is on the extender?
    What method of setup did you use? WPS or the browser based installation assistant?
    • rgerst's avatar
      rgerst
      its a mediacom router, i used the nighthawk app to install it as per its instructions, its weird that my onn stick does not recognize it... my original extender will find this new one and boost from it an my onn stick will hook to it just fine... I am not a technical person at all.... its just wierd
      • rgerst's avatar
        rgerst
        its a netgear ac1900 dual band wifi mesh extender, model ex6400
