OnTheRiver
Apr 08, 2019Tutor
Onstar Vehicle Range Extender
I have a GM vehicle with the Onstar WIFI Hotspot and an AT&T unlimited plan.I have an RV travel trailer used for extended stays in various types of camping sites. The range of the vehicle hotspot is a...
- Apr 17, 2019
Can now answer my own guestion and solve the problem. After 6 failed attempts at setting up the extender in the vehicle for extending the range of the Onstar WIFI hotspot with my tablet (5.2 Android Samsung NotePro) and phone (6.0 Android LG), I took my laptop with Windows 10 to the vehicle for the 7th attempt and the EX6100v2 set up right away - almost text book. Don't know why or what for the older Androids did not work.
Christian_R
Apr 12, 2019NETGEAR Employee Retired
Hello OnTheRiver,
If your hotspot has a WPS button you should be able to connect that way if not you will need to connect to the extender and go to www.mywifiext.net then do the setup and connect to the aircards wireless network.
~Christian
