rickjnash's avatar
rickjnash
OpenDS N300 router & Nethear range extender
I purchased the N300 Router for the parental controls, this is all working.:)
I have added a Netgear Universal Range Extender and I can get this connect and use the web OK.:)
However if:
I login in using the user utility into my parental controls account.
If I connect direct to the router I can access sites that are normally blocked, as my account has access to them i.e. www.facebook.com.
However if I connect to the network via the extender I am blocked.:confused:
  • sorry more product info I have a:
    N300 Wireless Dual band Modem Router (DGND3300)
    and a:
    Netgear Universal WiFi Range Extender (WN3000RP)
  • I am having the same problem.
    I have a Netgear WNDR3800 and just added a WN2000RPT (extender).
    Extender has been added to same network with a static IP.
    Everything was fine when laptop with bypass account connected to WNDR3800.
    But now connecting to WN2000RPT the bypass setting does not work. Everything from the Parental Controls is being blocked.
    Please advise on how to fix this.
  • this already discuss in the past.
    this is common issues on extender add to the network breaks LPC when connected to extender
    contact support at my.netgear.com
