Floyd-RBR50
Nov 22, 2020Aspirant
Options to extend wifi to detached shop
I'm wanting to get wifi to my detached shop (brick) that is about 50 feet from the garage that is attached to my house (brick). I have an RBS50 on the side of the house closest to the garage. The RBR...
jeff88ix
Nov 26, 2020Aspirant
I have a similar question,
I have an EX2700 extender in my house garage and would like to connect to another EX2700 in a detached shop. Can this be a hardwired ethernet connection? I already have the wire run to the shop.
Thanks
Jeff
- plemansNov 26, 2020Guru - Experienced User
The EX2700 doesn't have access point mode. That's the mode that'd allow you to hardwire it to your router.
- jeff88ixNov 26, 2020Aspirant
Thanks, any suggestions on a hardware combo to achieve this?
Do I just need a different extender with access point capability for the garage and move the EX2700 to the shop?
Thanks
Jeff
If you're hardwiring in a device you can use and extender that has access point mode, a router with access point mode, or even just an access point. Kind of up to you which route you go
