UncleBob1958
Sep 28, 2024Follower
orange light on Netgear Nighthawk x6s AC4000 extender
So when i plug in the Extender the power light comes on in orange, then that's all it does. Have tried doing the reset and still nothing happens. It started doing this after the unit was shut off for...
Sep 30, 2024Guru - Experienced User
Do you mean the EX8000? AC4000 is a speed, not a model
Did you push and hold reset for 7-15 seconds while its powered on or until the lights change on it?
Then you have to give it a few minutes to fully reboot (longer than you think)
