John_ncrr
Nov 08, 2022Follower
Orbi AC2200 Tri-band WiFi Router (RBR20) -add extra-strong satellite
I have a good stable Orbi AC2200 but have moved into a unit and need to add a satelite with extra boast to get the signal through a concrete floor (no options for drilling for wired connection or po...
- Nov 08, 2022
the ones you can use is RBS20, RBW30, RBS40, RBS40V, RBS50, RBS50Y
Any chance there's coax ran throughput? moca adapters work well
Nov 08, 2022Guru - Experienced User
