qttire1
Apr 23, 2024Guide
orbi or extender which one is best
I am currently using the nighthawk r8000 router but I have a 100' long house and the router is located at one end and the other end gets very weak signal. checking to see if anyone could recommend th...
Apr 23, 2024Guru - Experienced User
I'd try a EX8000 extender to see if this is all that you need.
