qttire1
Apr 23, 2024Guide
orbi or extender which one is best
I am currently using the nighthawk r8000 router but I have a 100' long house and the router is located at one end and the other end gets very weak signal. checking to see if anyone could recommend th...
Apr 23, 2024Guru - Experienced User
I'd try a EX8000 extender to see if this is all that you need.
qttire1
Apr 23, 2024Guide
yes I saw that one for a little more money the ax6000 seems to be better, can you tell me the difference between the ex8000 and the ax6000. the ex8000 only say coverage is 2500 sqft and need more than this.
- FURRYe38Apr 23, 2024Guru - Experienced User
What is the total size of this home in Sq Feet?
- qttire1Apr 23, 2024Guide
7000 sq ft but it is 100 feet long and the router is at one end of the house now? thought the orbi systems were expensive that is why i stayed away looking at them. but if the rbk763 makes more sense I may start looking at those. is this the
- plemansApr 23, 2024Guru - Experienced User
You've been covering 7000sqft with a single router on one end of the home? Dang.
I usually don't recommend a single router solution for over 2500sqft and you're way over that.
What speeds do you pay for?
You'll see a big difference moving from a single router solution to a mesh solution with 2x satellites for that coverage.
