qttire1
Apr 23, 2024Guide
orbi or extender which one is best
I am currently using the nighthawk r8000 router but I have a 100' long house and the router is located at one end and the other end gets very weak signal. checking to see if anyone could recommend th...
qttire1
Apr 23, 2024Guide
yes I saw that one for a little more money the ax6000 seems to be better, can you tell me the difference between the ex8000 and the ax6000. the ex8000 only say coverage is 2500 sqft and need more than this.
Apr 23, 2024Guru - Experienced User
What is the total size of this home in Sq Feet?
