qttire1
Apr 23, 2024Guide
orbi or extender which one is best
I am currently using the nighthawk r8000 router but I have a 100' long house and the router is located at one end and the other end gets very weak signal. checking to see if anyone could recommend th...
Apr 24, 2024Guru - Experienced User
Your right, I mixed up the 760 series with the 650 series. The 650 series has the 750 RBR and 350 RBS. My bad.
I'd still for for a 8 series. Better longevity.
qttire1
Apr 24, 2024Guide
thanks for all the help for both of you. I am paying for 1 gig and on phone speed test is usually around 280 to 300 mbps. that is another good question what is the best source to test internet speed. I have been using the netspot app and seems to do well.
- FURRYe38Apr 24, 2024Guru - Experienced User
I recommend and use Ooklas installable speed test app on mobile devices and PCs and laptops. Wired speed testing is preferred as it shows best and most accurate results.
- plemansApr 24, 2024Guru - Experienced User
I'd check out these 2 reviews (with a grain of salt).
https://dongknows.com/netgear-orbi-ax4200-rbk752-review/
https://dongknows.com/netgear-rbk852-orbi-ax6000-wifi-6-system-review/
both are solid systems and you're dedicated backhaul gives you a little advantage for either one of them.
I don't think either would be a bad choice. Compared to the R8000 you're coming from, its going to be much faster/better coverage all around
And I usually test a few sites. Mainly ookla and then xfinity's speedtest app. Sometimes ookla struggles to max out multigig speeds so that's when the ISP's site can help. For wifi testing I use ookla.
If I'm really testing speeds (faster than the ISP supports) then I use iperf3 but I've heard windows isn't recommending iperf3 because its emulated on windows. they recommend ntttcp
