SSCZA
Feb 17, 2018Aspirant
Orbi RBR50 - "No such file or directory"
I am using an ORBI RBR50 - base and one satellite. Set up and was working great. Reorganized office and moved the base. (actually almost swapping the base and satellite). Connecting to a new network w...
- Feb 18, 2018Thank you. Every device was impacted.
I follow the recommendation from another thread to reset my Orbi and set up again. That seems to of done the trick and I’m back up and running again.
Thanks for following up!
jvasanth1984
Feb 18, 2018Virtuoso
Hi SSCZA,
Do you experience this on all devices or specific device? Was the same device able to access those websites when connected wired to Orbi router?
- SSCZAFeb 18, 2018AspirantThank you. Every device was impacted.
Thanks for following up!- jvasanth1984Feb 18, 2018Virtuoso
Hi SSCZA,
Good to know that reset and reconfiguring the device resolved your issue.
