colinfw's avatar
colinfw
Initiate
Sep 08, 2023
Outdoor satellite or range extender for Netgear Nighthawk Mesh WiFi 6 System?
Hi! I have a Netgear Mesh AX1800 MK63 WiFi 6 system. I would like to add one or two outdoor satellites or outdoor range extenders to the system, preferably Netgear products, so as to have better WiFi in the yard. What do you recommend as the best compatible products for this?
1 Reply
  • plemans's avatar
    Netgear doesn't have any of the MK series that are outdoor rated.
    The RBS50Y is outdoor rated but is a bit spending and won't "integrate" with the system. And it'd have to be in extender mode.
