mattjohncook
Feb 13, 2020Aspirant
Outdoor studio problem
I currently use a NETGEAR WiFi Plug in extender (PLW1000/PL1000) to boost signal from the router by our front door to the back of the house (downstairs). This works well for our needs (and provides s...
DexterJB
Feb 19, 2020NETGEAR Moderator
Hi mattjohncook, yes, if the the PLW1000 originally worked out in the studio then that means that the electrical line is connected to to the main house which works well for powerlines.
Dexter
- mattjohncookFeb 20, 2020Aspirant
Thanks Dexter. Does that mean I can just stick another PLW1000 into the chain? Or would I need a pair? Would a pair be economical / work? Thanks, Matt
- DexterJBFeb 25, 2020NETGEAR Moderator
Hi mattjohncook, both would work. I'm not sure though if you can purchase one that isn't part of a kit/bundle/pair.
Dexter
- mattjohncookFeb 26, 2020Aspirant
Thanks Dexter. I did find one on eBay being sold by an electronics firm second hand, wired not wireless, but when I messaged them they said it wouldn't work. I guess I'll have to suck it and see. Thanks again for your help. Matt
- DexterJBFeb 27, 2020NETGEAR Moderator
You're welcome Matt!
Dexter
