mattjohncook
Feb 13, 2020Aspirant
Outdoor studio problem
I currently use a NETGEAR WiFi Plug in extender (PLW1000/PL1000) to boost signal from the router by our front door to the back of the house (downstairs). This works well for our needs (and provides s...
DexterJB
Feb 19, 2020NETGEAR Moderator
Hi mattjohncook, yes, if the the PLW1000 originally worked out in the studio then that means that the electrical line is connected to to the main house which works well for powerlines.
Dexter
mattjohncook
Feb 20, 2020Aspirant
Thanks Dexter. Does that mean I can just stick another PLW1000 into the chain? Or would I need a pair? Would a pair be economical / work? Thanks, Matt
