mattjohncook
Feb 13, 2020Aspirant
Outdoor studio problem
I currently use a NETGEAR WiFi Plug in extender (PLW1000/PL1000) to boost signal from the router by our front door to the back of the house (downstairs). This works well for our needs (and provides s...
DexterJB
Feb 19, 2020NETGEAR Moderator
Hi mattjohncook, yes, if the the PLW1000 originally worked out in the studio then that means that the electrical line is connected to to the main house which works well for powerlines.
Dexter
DexterJB
Feb 25, 2020NETGEAR Moderator
Hi mattjohncook, both would work. I'm not sure though if you can purchase one that isn't part of a kit/bundle/pair.
Dexter
- mattjohncookFeb 26, 2020Aspirant
Thanks Dexter. I did find one on eBay being sold by an electronics firm second hand, wired not wireless, but when I messaged them they said it wouldn't work. I guess I'll have to suck it and see. Thanks again for your help. Matt
- DexterJBFeb 27, 2020NETGEAR Moderator
You're welcome Matt!
Dexter
- mattjohncookMar 04, 2020Aspirant
Hi Dexter
Me again! I've added a PLP1000 in the house for the TV, and moved the PLW1000 to the outdoors studio. Both work, but not in tandem. If the PLP1000 is switched on inside the house the wireless connection outside drops out. Is there a way to get both to function at the same time? Or could it be that the inside one is plugged into an extender? It's hard to fit it into the wall directly and seems to work OK in giving the TV the bandwidth it needs.Thanks again for your advice.
Matt
