setuphelpneeded
Mar 27, 2020Follower
Painful Set Up Process
Hi Netgear Community, Hoping that reaching out with this issue will lead to a solution and end the painful setup process with Netgear. For context, my wifi works to ~40 feet (estimate for illustrat...
Mar 27, 2020Guru - Experienced User
What is your interior walls made? Materials matter big time with wifi. Certain ones like brick, concrete, plaster lathe, adobe, foil lined insulation can all do a great job of blocking wifi. In those cases, usually extenders don't help as they need a good signal to function off of.
