ewright
Apr 30, 2020Aspirant
Password not accepted on N300 WiFi Range Extender
I have just purchased my N300 WiFi Range Extender Model EX2700 and I have connected it to my router and plugged it in halfway between where I have internet and where I lose reception. All lights are ...
Apr 30, 2020Guru - Experienced User
Did you set it up using wps?
If so, factory reset it and reinstall using the installation wizard.
Not all device makers code wps the same and it can cause issues.
ewright
Hiya,
Do you mean factory reset the extender? and then try with the Netgear Installation assistant rather than WPS?
I am not great with computers! Thanks
plemans wrote:Did you set it up using wps?
