egrani
Oct 04, 2019Follower
Password Reset (mywifiext.net)
Need help resetting the password for https://www.mywifiext.net. Security questions not working and we realize it's case sensitive. Also the password is different from netgear.com for some reason appa...
mbj9610
Jun 30, 2022Aspirant
when i need to login to my netgear network, a message say that a password iis reguired. but when i prees the massage on login page. no login page appers?
also tryed the nighthawk app. then the massage appers: the app do not suport my synology wifi router.
also tryed to reset the router and the extender.
- olympos1625Jul 14, 2022NETGEAR Employee Retired
Hi @mbj9610,
Thank you for reaching out. We are sorry for not being able to get back to you immediately. When you say," when I need to login to my Netgear network, a message says that a password is required" Are you talking about the router or extender? Did you try to re-setup the extender and see if the error still occurs?
I am looking forward to your response.
Oliver
Community Team
