MaxVor
Feb 07, 2021Aspirant
Pc can't connect to extender ex3110
Hi, I recently bought the ex3110 extender for my appartment, and I am having a lot of trouble with it. It worked alright for a while, but now it won't connect to my laptop anymore (asus). It ...
Feb 07, 2021Guru - Experienced User
What router is it connect to?
Are you installing it using WPS or using the installation assistant?
MaxVor
Feb 08, 2021Aspirant
Hi, thanks for your reply.
it's connected to a freebox, model F-GW06250C.
i installed the extender with the installation assistant.
best regards
- plemansFeb 08, 2021Guru - Experienced User
I couldn't find much info on that specific router. Looks like maybe a single band router?
have you tried setting it up using fastlane mode with the 2.4ghz as the backhaul?
