MaxVor
Feb 07, 2021Aspirant
Pc can't connect to extender ex3110
Hi, I recently bought the ex3110 extender for my appartment, and I am having a lot of trouble with it. It worked alright for a while, but now it won't connect to my laptop anymore (asus). It ...
MaxVor
Feb 08, 2021Aspirant
Hi, thanks for your reply.
it's connected to a freebox, model F-GW06250C.
i installed the extender with the installation assistant.
best regards
Feb 08, 2021Guru - Experienced User
I couldn't find much info on that specific router. Looks like maybe a single band router?
have you tried setting it up using fastlane mode with the 2.4ghz as the backhaul?
