Barb28n
Jul 11, 2020Aspirant
PC will not connect to internet
My PC will not connect to the internet using the netgear+ext network, but my phone will, Sorry if this has been asked before, but I cannot find any solution
Jul 11, 2020Guru - Experienced User
What router are you connecting to?
Firmware on the extender?
Did you set it up via wps or using the installation wizard? wps gets coded different between different manufacturers. In that case, the installation wizard many times works better.
Barb28n
Jul 12, 2020Aspirant
The router is an Arris tr4400 supplied by spectrum, I connected it wirelessly using the wizard, I updated the firmware to the latest version, My pc see the network, and connects to it, but it doesn't connect to the internet. I have no idea what to do next, any help would be appreciated, Thanks
- plemansJul 12, 2020Guru - Experienced User
is this the one?
https://fccid.io/UIDTR4400/User-Manual/User-Manual-3519922
its a RAC2V1A
Its known to have issues with extenders.
You can try going in and disabling its mac filter.
