SeanLeroy
Apr 15, 2020Aspirant
Ping Issue/Gaming Issue
I have a issue with my internet and it's having a lot of bad ping. Such as the game Fortnite, it says that I'm far away from NAE Servers but I literally live in the State of Maryland. Which is in th...
SeanLeroy
Apr 16, 2020Aspirant
I just realized that my ethernet wasn't connected to the box, my bad here's another test.
Apr 16, 2020Guru - Experienced User
so you're pulling 200+mbps over wireless and only 70+ over wired? is that correct?
run the ping plotter test on dslreports.com
Reason I say this is if the speeds are good coming from the router on a dslreports.com, its not the modem or the line. Its the game sever that's being used.
BTW. my band, the C3700 is dual band. Was thinking a different device.
- SeanLeroyApr 16, 2020Aspirant
That is the DSL ping report that you gave me, I don't understand the results if you can explain to me (it's in the screenshot), if so thanks. And what if I called Netgear would that be a good Idea also, here's the thing I have Comcast/Xfinity but a NETGEAR Modem I don't know if that means anything but just stating that out there.
- plemansApr 16, 2020Guru - Experienced User
try using using a different dns provider. you can try google's at 8.8.8.8 or 8.8.4.4 or cloudfare's at 1.1.1.1
Yeah, so the 8 thing doesn't work, so I tried cloudfare it says that it's coming out sometime soon is there anything else I can try? Also, what does this do?
SeanLeroy wrote:Yeah, so the 8 thing doesn't work, so I tried cloudfare it says that it's coming out sometime soon is there anything else I can try? Also, what does this do?
I don't think you're doing it right because I'm using cloudfares with google as a secondary right now.
https://kb.netgear.com/30510/How-do-I-set-static-Domain-Name-System-servers-on-my-NETGEAR-router
- SeanLeroyApr 17, 2020Aspirant
Hi, Sorry for responding so late but is there anything else so easier then doing all of this and also do I contact Xfinity or Netgear for help. I just want an easy way, and play games. But all of this is kind of confusing to me if so, Thanks.
- plemansApr 17, 2020Guru - Experienced User
SeanLeroy wrote:Hi, Sorry for responding so late but is there anything else so easier then doing all of this and also do I contact Xfinity or Netgear for help. I just want an easy way, and play games. But all of this is kind of confusing to me if so, Thanks.
I'm not sure what to tell you. No, there's no "easy" button.
Part of owning your own gear is sometimes having to try different settings to get it working better for your services.
And with so many people being home right now, game servers are also getting inundated.
Your options?
1. Get an isp supplied device. Might work better, might work worse.
2. buy a gaming router like the XR500 and your own modem only device. That way you can seperate out where the issue is coming from
3. work on your device. Play with settings. work with your isp if its a line issue.
you're speeds are fine. Your ping is a little high. There's a few things you can do to help that. But there's no "easy" fix.
https://www.cnet.com/how-to/heres-how-to-get-lower-ping-for-online-gaming/
- SeanLeroyApr 22, 2020Aspirant
Here you go, I contacted my ISP here's there response they did a modem reset and it's still doing the same thing but the told me this:
https://prnt.sc/s468t1 (In the screenshot)
