Trelawney7
Sep 13, 2019Aspirant
PL1000 and EX6100 AC750
I have just purchased a PL1000. Will it create a wifi hotspot, and/or can my EX6100 AC750 create a hotspot, or do I need the PLW1000?
Trelawney7
Sep 14, 2019Aspirant
Thanks. I’m getting an unidentified network/no internet when plugged into the second PL1000.
Haven’t tried the extender yet as need to get a useable connection on the Powerline?
- plemansSep 15, 2019Guru - Experienced User
Setup the powerline devices in the same room first. Just to get everything connected and working fine. If you can't get them setup in the same room (aka same circuit) then either something is wrong with them, they're hooked up wrong, or something is seriously causing interference in your wires.
Once they've established connections with each other they basically work as a ethernet wire.
- Trelawney7Sep 15, 2019AspirantThanks-yes is already done that and that worked fine.
- Trelawney7Sep 20, 2019Aspirant
Any other ideas?
