Retired_Member
Dec 28, 2019PLEASE HELP - "No Connection" 2.4GHz AC1900 WiFi Range Extender
Hi - I am really at a loss here. I have the AC1900 and everything appears connected but the 2.4GHz extenstion says "no connection." This happened suddenly as things were working perfectly before. ...
bdemaiffe
Nov 03, 2020Aspirant
I'm having the same issue. Did you find a solution?
- plemansNov 03, 2020Guru - Experienced User
rahmat_rahman bdemaiffe suggestion would be to start your own thread and not jump on someone elses. it confuses whats going on with the OP. Its why thread jumping is part of the terms and conditions and starting your own is encouraged. We're happy to help, just start your own.
