Westovers
Mar 12, 2023Aspirant
Please help: I can't connect my EX6100 to my T-Mobile Nokia 5621 Gateway...
It can connect through my older wireless D-Link router, but not directly to the Nokia Gateway. Is it not compatible?
Mar 13, 2023Guru - Experienced User
From researching that router it seems like they have an option for mesh with it to add nokia's beacons (their own mesh setup).
Not 100% as I don't have one to play with.
You could look to see if there's anyway to disable that in settings as that can create issues.
- WestoversMar 13, 2023Aspirant
Ugh. Just realized I mistyped--it's the T-Mobile Nokia 5G21 Gateway (not 5621) that I'm trying to connect to... (How may I edit my original post?)
I don't seem to have access to few, if any, settings... Do you see a user manual with instructions or details anywhere for how to do what you are proposing?
- plemansMar 14, 2023Guru - Experienced User
I did lookup the 5g21. It might be worth talking to either nokia/tmobile about its potential for adding an extender and what settings are available.
